1995 chevy balzer 4x4 4 door trying to find fuel schrader valve
Cant seem to start my balzer
cant find fuel pump fuse under the drivers side dash Have a After market alarm system cant find alarm fuel cutoff Can someone please direct me in the right path to fix this also having problems with ac need vacum line diagram or something, blows out window and floor on all controls no dash air |
RE: 1995 chevy balzer 4x4 4 door trying to find fuel schrader valve
The fuel pressure test port is located off the back side of the intake plenum near the brake booster and just below the seam between the upper intake and lower intake halves.
As far as a vacuum line diagram, maybe check Autozone.com. They sometimes have these things. |
There is a fuel pump relay in your glovebox. Behind the access panel.
Is it getting gas? Is it getting spark? That will help narrow it down. |
| All times are GMT -5. The time now is 09:21 AM. |
