-   -   1995 chevy s-10 Blazer won't cold start (https://blazerforum.com/forum/engine-transmission-35/1995-chevy-s-10-blazer-wont-cold-start-67927/)
Sky 02-12-2012 07:25 PM
I have a 1995 s-10 blazer that will not start when it is cold out. During the summer, it starts up no problem. as soon as the cold weather hits, it won't start. If i leave it in my garage with the heater on, it will start up after a while without a problem and will run. If it sits too long in the cold afterwards, then it won't start yet again. I have put a new fuel filter, fuel pressure regulator, pickup coil, coil, plugs, plug wires, distributor cap, rotar button, and crank sensor on it. It is still having this problem. Any helpful advice would be appriciated!!!!
swartlkk 02-12-2012 07:36 PM
Have you tested your fuel pressure when the no-start condition occurs?
Sky 02-12-2012 07:45 PM
yes i did. It was about 55 psi
swartlkk 02-12-2012 07:47 PM
It needs to be >55psi for proper operation of the engine, but lets assume that your gauge reads low and move on.
Have you tried wiggling the wires that run to the fuel injection spider inside the manifold? They exit under the throttle body.
What brand of ignition components did you use?
Sky 02-12-2012 07:50 PM
what would wiggling the wire do for it?
swartlkk 02-12-2012 07:53 PM
Many people have chased problems only to find that the connector on the injector inside the plenum was loose & in need of replacement. Pulling the wires can allow the contacts to complete the circuit resulting in a working engine, even if temporary.
Sky 02-12-2012 07:57 PM
If thats what the problem is, then why does it only do it when its cold outside?
swartlkk 02-12-2012 07:58 PM
For something that is so easy to try, I'm not sure why you are being so hard headed about it... Regardless, I'll play your game this once, but then I'm out. When its cold out, wires constrict, plastic moves, etc.
Good luck with your problem.
Sky 02-12-2012 08:01 PM
sorry about that, i'll give it a try. And thank you
So I tried to wiggle the wires, but all it wanted to do is just crank over, like its been doing. Still won't start
247monster 02-12-2012 08:28 PM
it sounds like your battery is weak to me...happens alot up here when it gets cold easy to check too but its also easy to forget
