1995 fuel system questions
I recently got a '95 blazer with 4.3l that needs some fuel system tlc so I was pondering ideas for a frankensteined system. I currently have the CPI spider and I'm wondering if the new MPFI injector diameter would fit in the intake holes where the poppet valves are? Also, I'm wondering what the current draw is for the new injectors compared to the original maxi injector? Would the computer be able to ground all six injectors instead of the maxi injector? Thank you.
Originally Posted by Alwaysfixing
(Post 743919)
I'm not looking to just plug and play. I'm looking to make it compatible. I just figured I would see if I could gather some info before blindly jumping into the project. Anything is compatible with enough ingenuity and imagination.:icon_biggrin:
