-   -   1995 Jimmy 4X4 Automatic Tranny Oil Change (https://blazerforum.com/forum/engine-transmission-35/1995-jimmy-4x4-automatic-tranny-oil-change-59952/)
the Fllash 06-12-2011 01:24 AM
I changed my 1994 Jimmy 4X4's automatic transmission oil and filter. On the back side of the transfercase there is a drain plug and I removed that and automatic tranny fluid drained out.
My question is when I refill the automatic tranny via the dipstick/tube will that fill the transfercase too?
It only took about 5 quarts of oil to bring the dipstick to the full mark.
Thanks for your reply.
The Fllash
oisinirish 06-12-2011 09:57 AM
Most likely the transfer cas was filled with trans fluid. That is pretty standard on the older ones. Like mine. I suspect you will need to fill the transfer case separately. The two systems are not connected, I don't believe.
How much fluid came out of the tranny? How much from the transfer case? 5 quarts seems short to fill both.
What I could find:
Tansmission on fluid change takes 5 quarts.
Transer case=Should be a tag on the back.
Np231 and 233=1 quart
Nv136 and 236= 2 quarts
the Fllash 06-12-2011 01:19 PM
oisinirish,
Thanks. I checked my owners manual this morning and yes it does fill separately and uses ATF.
