1996 4.3 blazer help please
Old Mar 13, 2025 | 03:23 PM
Jmcgee4609's Avatar
Jmcgee4609 is on a distinguished road
Default 1996 4.3 blazer help please
Has 161,000 miles I have noticed antifreeze leaking but can’t tell if it’s the intake or head gaskets. It’s coming from both sides. I presure tested but nothing that I can see. But definitely leaking. No water in oil or smoking. Please any advice would help.
Old Mar 13, 2025 | 04:15 PM
GeorgeLG's Avatar
Pressurizing the system with a tester may promote the leaking to identify the spot. Rinse the engine first and let it dry then pressure test cold engine off. Wipe around with white paper towels. Look around the heads, freeze plugs, hoses, heater core and water pump. If your still struggling try dye and a blacklight with the pressure tester. Lastly do a compression test.
George
pd95blazer
26
Oct 19, 2011 02:05 PM
wild bill
Apr 7, 2011 11:22 AM
chris015
Apr 28, 2009 11:29 PM
laurstevechar721
Nov 11, 2008 05:37 PM
Navy85
Apr 27, 2008 03:49 PM
