1997 Blazer LT MFPI swap and now its smells of gas and blowing white smoke
Old 02-18-2018, 06:29 PM
skubasocks's Avatar
skubasocks is on a distinguished road
Default 1997 Blazer LT MFPI swap and now its smells of gas and blowing white smoke
My blazer needed the spider replaced, only realised after i had swapped plugs, wires, cap and rotor, and the catalytic converter. Im stumped though now. Right after replacing the spider with a new MFPI, It started up first crank ran great for a test drive. So i parked it for a couple hours and then it threw p0303. I drove it last night and it would hesitate on acceleration and sometimes try to stall. Then today i start it up and its blowing white smoke. I cant find any one else with this issue. NEED HELP badly!!! Thank you
1997 chevy blazer LT
4.3 vortec
Automatic
164***
Old 02-19-2018, 07:12 PM
LesMyer's Avatar
LesMyer will become famous soon enough
Copious amounts of white smoke is typically coolant burning in a cylinder from a cracked head or bad head gasket or bad intake gaskets.
Old 03-28-2018, 11:32 PM
Jonahdek's Avatar
Jonahdek is on a distinguished road
4.3 vortec
Automatic
164***
hey did you get this resolved? I have a 1997 gmc jimmy SLE and i just swapped my injectors to mpfi and have the exact same issue. I held a blowtorch to the white smoke bellowing out of my exhaust and it lit up like a roman candle. Its definitally fuel thats causing it. Not sure if the injectors i just bought are faulty or if i have bad plugs or wires. Was working fine before i did the mpfi conversion, aside from the rough idle due to leaky cpi injectors. Let me know if you resolved the problem and how. Thanks
Bubba2996
06-25-2015 12:20 PM
matt92
05-01-2011 04:39 PM
doelleb85
12-24-2010 11:43 PM
Chochi
06-06-2009 11:19 PM
vernoninmd
02-24-2008 11:52 AM
Quick Reply: 1997 Blazer LT MFPI swap and now its smells of gas and blowing white smoke
