-   -   1997 Blazer transmission completely gone?? (https://blazerforum.com/forum/engine-transmission-35/1997-blazer-transmission-completely-gone-29807/)
troyky29 04-20-2009 12:15 AM
I'm sure I already know the answer, but figure I would make sure. I have a 97 Blazer 4x4 with 190,000 miles. When I bought it, it had 174000, and the transmission had just been rebuilt. Since getting it I had the shift solenoids replaced by a shop. Yesterday I drove it down the road and when I stopped and took off I was getting a slight grinding noise and some jerking. It then took off and drove fine, When I stopped again, I got the same thing, but this time it would not move. All gears were lost including reverse. After checking the fluid which was fine, I tried it again and it moved a couple feet then lost everything again. I know the transmission is probably shot, but not being a mechanic, I am just trying to confirm this. Never seen one go that fast.
swartlkk 04-20-2009 11:26 AM
Have these problems gotten worse since your August 2008 post discussing issues with your transmission?
If so, then I would say a complete rebuild is in order.
troyky29 04-20-2009 02:29 PM
The problem before was a shift solenoid had both replaced at a shop and it has been fine since then.
swartlkk 04-20-2009 03:20 PM
Was your current problem an instantaneous one or did it slowly get worse?
troyky29 04-22-2009 06:13 AM
It just went out all at once. No warning signs until a few minutes before. When I stopped and took off, I got a clunk and a jerk. When I stopped again it did not take back off.
swartlkk 04-22-2009 09:22 AM
Definitely sounds like one of the hard parts in the transmission went.
