1998 blazer can't get the check engine light off
Old Jul 28, 2013 | 05:09 PM
seang1989's Avatar
seang1989 is on a distinguished road
Default 1998 blazer can't get the check engine light off
I have a 98 blazer 2 wheel drive and my check engine light stays on. I replaced the transmission and put a 96 tranny in it. It runs fine but the code is the tcc solenoid. I replaced both but its still the only code popping up. Any ideas on what might be going on?
Old Jul 28, 2013 | 06:11 PM
chris015's Avatar
electric differences. the 96 wasn't a exact drop in for you. 96-97 is a 2 year deal,and 98-99 is too. I dont remember whats exactly different.
Is your overdrive(4th) working? if so,i wouldnt worry about it. If not,you are going to have 3 gears,and the trans will run hotter. Id advise you to install a tranny cooler.
Old Aug 2, 2013 | 10:21 AM
seang1989's Avatar
It isn't working. Everything works fine except that it won't go into overdrive and the tranny isn't running hot. I just need to get the tcc code off. Its out of inspection and I can't get it inspected with the check engine light on.
GREZ28
Jun 25, 2011 08:58 AM
KRUSHER
Jan 2, 2010 07:25 PM
acooper114
Dec 20, 2009 02:19 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
jagblazer01
13
Jan 25, 2007 12:54 AM
