1998 Blazer vacuum actuator specs
Old Oct 18, 2010 | 06:18 PM
stephani555's Avatar
stephani555 is on a distinguished road
Default 1998 Blazer vacuum actuator specs
I am needing the vacuum specs. for a 1998 chevy blazer. 4WD won't engage when you push button but if you run a vacuum line directly to the actuator it engages. The vacuum line running from the vacuum switch has very little vacuum but has new switch. How much vacuum should be on the line coming from the switch?
Old Oct 18, 2010 | 09:01 PM
ArRay68's Avatar
ArRay68 is on a distinguished road
Does the a/c controls work(floor,vent, defrost)? I mean change when selected.
I would check where the vacuum is supplied on the intake. That connection dry rots.
Old Oct 18, 2010 | 09:48 PM
Vacuum level at the actuator when the 4wd is engaged should be close to the vacuum level present at the intake manifold vacuum source.
Old Oct 19, 2010 | 01:01 PM
ArRay68 & swartlkk - I have verified all the controls work. I did find a bad vacuum cable line on the intake but still have very low vacuum at the 4wd actuator. thx
Old Oct 19, 2010 | 05:54 PM
ArRay68's Avatar
see if you can locate the check valve from the canister to the 4wd solenoid. that sounds like it will be isolated to the line that is from the canister to the solenoid. My 2 cents have been applied.
Old Oct 19, 2010 | 05:57 PM
ArRay68's Avatar
i just brain stormed. You may split the control vacuum line to connect to the solenoid for the 4wd. WYE off it is what I am trying to say.
Old Oct 31, 2010 | 08:39 AM
shane216's Avatar
shane216 is on a distinguished road
there is a vac switching valve that is on top of the transfer case, it has a ball and spring in it and when 4wd is on it sends the vac to the actuator. there is a vac hose that runs from the engine to the transfer case and then couples with 2 other hoses into a connector that plugs into the switching valve. check the line going from the motor to the t case and make sure there is no holes or cuts if thats ok take the switching valve out and see if its stuck they are under $20 i just had to replace mine
dillbob123
Aug 26, 2014 02:24 PM
SyberTiger
Jul 3, 2014 01:09 PM
markrd
May 8, 2009 01:39 PM
toofancy83
Dec 11, 2008 11:23 AM
rooster
Feb 18, 2007 07:16 PM
