1999 Chevrolet Blazer LT 4WD SUV engine knock from underneath
Hi, I am new here and would greatly appreciate some help
Car: 1999 Chevrolet Blazer LT 4WD SUV Problem: engine knock coming from underneath engine, oil pressure rises as I press on gas (knocking gets louder). What have I tried: Using stop knock to try to quiet lifters. I would appreciate any insight I'm leaning towards a bad bearing or lifter due to the previous searches. :icon_attention: |
anyone?
Car: 1999 Chevrolet Blazer LT 4WD SUV Problem: engine knock coming from underneath engine, oil pressure rises as I press on gas (knocking gets louder). What have I tried: Using stop knock to try to quiet lifters. I would appreciate any insight I'm leaning towards a bad bearing or lifter due to the previous searches. :icon_attention: When bearings go out, fine metal particles get into the oil. If you let a sample of old engine oil settle overnight you can see the metal particles as a shiny layer when you pour from one glass container to another. Bearing knocks can also be diagnosed by inducing a miss into each cylinder, one at a time by pulling a plug wire. When you find the cylinder that quietens when it misses, you have found the one that is knocking. Good luck |
| All times are GMT -5. The time now is 12:25 PM. |
