2000 Blazer 4.3l No Start
Old Mar 1, 2023 | 08:58 AM
LegitSnow91's Avatar
LegitSnow91 is on a distinguished road
Default 2000 Blazer 4.3l No Start
I bought this Blazer and was told it only needed shift solenoids. I changed those. She ran for about a week and then stopped. First couple days I had to purge the motor before cranking and she would start right up. That eventually stopped working. Had her code checked, they said crankshaft position sensor. I changed that. Still no start. I'm fairly new to mechanics, it was more my husband's hobby and he didn't like apprentices. He's gone now so its my job now. I just need some pointers folks. Thanks
Old Mar 1, 2023 | 11:20 AM
LesMyer's Avatar
Go in order below and stop if a problem found. Report results.
1) test fuel pressure (loaner fuel pressure gauge from local parts store). Should get about 60 psi with KOEO for 2 seconds when key is first first turned on and hold above 40 psi pressure for some minutes.
2) test for spark at coil (spark plug on end of old spark plug wire plugged directly into coil, and spark plug grounded to metal on engine) - then crank and watch for spark to jump the gap.
3) test for injector pulses from PCM (big injector connector disconnected and noid light from local parts store across terms for one of the injectors) - then crank and watch for noid light to pulse.
Kmac81
Aug 11, 2014 08:21 PM
thekinz072
Jul 30, 2013 07:29 PM
jwp2332
Oct 6, 2011 01:12 PM
uncledenny
Oct 28, 2009 04:38 PM
