awesome!!!
dude that is awesome!! yea i ended up ordering one from ebay and it fired right up also...yea sorry it took so long to get back at ya guys but car is back up and running.
That's great guys! Thanks for sharing.
Dunno exactly what it was, though.. I didnt learn anything. ;) |
What Ebay seller did you acquire the pump from?
The name of the seller is aitc168
The item number is AUTO-SUMTO 160655593213 |
Thanks, Let us know if it dies. Good luck.
Originally Posted by pontiacguy
(Post 507345)
The item number is AUTO-SUMTO 160655593213 The guy's ebay store is Auto-Sumtown http://stores.ebay.com/AUTO-SUMTOWN/...d=p4506.c0.m57 but here's the first fuel pump for ours I came across. OLDSMOBILE BRAVADA 98 99 00 01 FUEL PUMP Brand New | eBay And reading WAY down... here's the specs GM # 25178729 PRESSURE: 3Bar FLOW: 120L/h It says on another source site 'Select a flow rating pressure above your operating pressure for best results'. So that would be 5 bar. Doesnt mean any given pump for that rating wont last.. it just reflects likelyhood of early demise, all else equal. |
Originally Posted by pettyfog
(Post 506888)
Thanks for the lesson on the bar thing (actually I googled for the lesson). I guess that pump must be underrated by that standard, because we already know that these two trucks (at least) won't run on 45 or 43.5 psi or whatever. So somewhere the math is wrong. My $20 pump peaks at 61 to crank and regulates at 55. But if I had a fat wallet and cost was no object, I'd just take it to the dealer and not worry about such petty nonsense.
(Post 507764)
Let me say it again. That is a design/production test standard to which the pump is built. The point is all production must meet or surpass. The absolute head pressure {return plugged} of one pump might be 100 lbs, the next.. 65 lbs. Either of those would probably pass 3 bar 120 lph. Look at it like this: Your house wiring if it's built in last 60 years is power/ insulation rated to 600 volts. Do you think you should settle for a 200 volt rating? 12 ga wire can actually handle 30 amp easily, it's never to be fused for more than 20. Should you put a 30 amp breaker on it, anyway? It would work fine.. almost all the time. |
| All times are GMT -5. The time now is 11:45 AM. |
