2000 blazer no start
Old Mar 4, 2013 | 11:45 AM
steve1969's Avatar
steve1969 is on a distinguished road
Default 2000 blazer no start
two weekends ago it sat for two days and monday it would not start. the fuel pump is less than two months old. i changed the cap rotors wires and plugs. still no start. i then changed the fuel filter and it started right up. ran great for three days. it sat again over the weekend and today it wont start. any ideas im really frustrated and not sure what to do next.
Old Mar 4, 2013 | 06:45 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Almost sounds like you may have a bad tank of gas, something may be clogging the filter.. Take the filter back off completely, put a hose over the line coming from the tank put the other end in a clear jar, have someone turn the key to the on position without starting it. Watch to see if you get a good flow of gas thru the line, it should only spray for a couple of seconds and then stop,, if so, check the gas in the bottle for any weird odors, also coloring of the gas. I got a tank of gas in my blazer one day and the next day the fuel pump died, The gas had the worst odor to it and the color of it looked like it had oil in it.. It killed both the fuel pump and the spider assy...once you`ve checked for flow and color, have someone crank the truck over for a second again with the hose in the bottle for gas, check the coloring again. Replace the fuel filter again with a new one. I use Fram filters. Hope any of this helps ya out.
Old Mar 4, 2013 | 06:49 PM
FsTFwRd's Avatar
Make sure your pump has a good ground. Assuming it does you may have trash in your tank. I've dealt with something like this before only on a full size pick-up. The guy had a nasty sludge sediment, settled at the bottom of his fuel tank and was screwing things up pretty bad. (cheap gas from a off brand gas station)
Old Mar 4, 2013 | 10:42 PM
steve1969's Avatar
i can hear the pump so i think thats ok. going to the garage tomorrow i hope its nothing to major but my luck has not been too good with this truck.
Old Mar 6, 2013 | 09:01 AM
steve1969's Avatar
thanks for thoughts i was leaning to a fuel issue as well. but it was the coil.
coolasice
Dec 9, 2024 09:53 PM
01Blaze218
Oct 13, 2011 10:05 AM
RLELLIOTT
Aug 2, 2007 04:18 AM
fremontt
May 7, 2007 12:42 AM
westernbronco
Jan 23, 2007 02:16 PM
