| fix-it-dad |
02-16-2015 10:05 AM |
2000 Blazer not shifting to any gears
Blazer has been shifting fine. Parked it last night, it was about 10 below 0, this morning nothing happens when you shift into any gear. I looked under the car and can see that the linkage is moving when the shift lever is moved. I don't know if this is related but I just replaced the rear disc brakes/rotor/calipers etc.... I test drove after the replacement and everything appeared to be OK. I have not checked the fluid level yet as this happened this morning and I needed to take another rig to work. Is there any way this could be caused by the cold?
