2000 blazer starting problem
Have a 2000 blazer has intermittant starting problems. Some days it will not start cold, other days it is fine. Turns over fine but acts like no gas. Mechanic says pump is working and has pressure. All it takes is about 10 minutes of a small electrical heater blowing on the cabarator and it starts right up. Could it be the fuel regulator.
Have you tried either having a professional fuel system cleaning done or just over the counter fuel system treatments? Sounds like you may indeed have sticking poppet nozzles when cold, but replacing the spider should be considered a last resort after cleaning has been attempted.
3D_Illustrator
Nov 13, 2015 01:46 PM
cramcam
17
Jul 11, 2013 08:32 AM
cgrett
Nov 15, 2010 09:08 PM
Sprocket
Mar 20, 2008 09:39 PM
