2000 Blazer surges at bit only when heater on AC is on
My Blazer runs great except it surges a bit in idle and drive only when the heater or AC is on. Wondering which sensor/switch might be the cause?
Thanks,
Matt
Thanks,
Matt
How substantial of a surge are we talking? Probably your a/c compressor kicking on/off. Unplug your compressor and see if the "surge" goes away.
Thats what I'm thinking. AC compressor. They always used to do this when you used the defrost setting on the heater to keep the clutches free even in winter. It will cause a slightly noticeable stumble under normal conditions. Really just a slight decrease in engine RPM is what it is. Just a little drag.
If you have automatic climate control, the A/C compressor can cycle in any setting except off. If you have manual HVAC, the compressor will only cycle in A/C and defrost settings. The compressor cycles in defrost to blow dehumidified air on the windshield to defog it quicker. The PCM will compensate for variances in engine RPM as the compressor cycles on and off, and you may or may not notice it.
Karen Beech
Oct 2, 2013 12:18 AM
Dadatone
Jul 26, 2012 12:28 PM
Bonzaibob
Apr 17, 2012 11:11 AM
cutlasskid84
Nov 12, 2007 06:27 AM
oshkosh
Jan 27, 2007 01:22 PM
