2000 hmm Jimmy np8 issues
Old Dec 7, 2018 | 09:31 PM
James M DeVore Jr's Avatar
James M DeVore Jr is on a distinguished road
Default 2000 hmm Jimmy np8 issues
Ok, I have a 2000 gmc
jimmy, np8 transfer case.the 4wd quit shifting some time ago. The lights on the 4wd selector buttons would flash sometimes. I replaced the vacuum actuator, I just replaced the transfer case shift motor and it still isn't shifting. The service 4wd light comes on. The vacuum actuator has vacuum and will pull the front axle into 4wd. What's wrong with my jimmy??
Old Dec 8, 2018 | 12:26 PM
Strangerock's Avatar
Strangerock is on a distinguished road
Have you checked the connections on the TCCM ?, they can get corroded and cause problems . It may help also if you read the service 4x4 code, ...can you hear the TCCM clicking when you try to select 4x4 ?
Old Dec 8, 2018 | 12:47 PM
Ditto on the TCCM; they can fail. When going bad you can sometimes hear them clicking multiple times.
bugsbunny16374
16
May 14, 2014 07:01 AM
beratzlaff
Apr 4, 2013 09:25 PM
bsmith
Jan 17, 2011 09:10 PM
jcw67
Jan 16, 2011 10:04 AM
mx534
Nov 25, 2006 10:14 AM
