2000 model engine overheating
Old Jan 5, 2010 | 03:49 PM
dandmprivate's Avatar
dandmprivate is on a distinguished road
Default 2000 model engine overheating
well here goes for first tiime.......
Had cyl head gasket replaced..both and now I can idle car all day with heater working and no overheating or water loss but when I travel say 20 miles at med speed ie 40/50 miles it over heats with big coolong system pressure........ release, cool and add more water/anti freeze mix all well for similar time.
Is this the gasket again..........
cooling system pressure test at 14 psi will hold for 30 mns with only about 1 psi drop, longer time no further drop
Compression test shown 105 to 110 psi on all cylinders..........
Spark plugs all showing same light brown colouring......
I am dreading another mass of money on this only to find same problem......
Any ideas
Should say prev owner must have run it without antifreeze as a lot of contaminants in system ie rust particles....... but with cleaner and in line filter this has cleared and no issues here.....this was done before issues.
Old Jan 5, 2010 | 05:15 PM
rriddle3's Avatar
Check to be sure the water pump is not leaking.
Northern Z7
Mar 14, 2015 05:38 PM
JackedJimmy
Jul 16, 2014 08:55 PM
-PHX-JustBlaze
Sep 5, 2011 08:07 PM
Jay2000jimmy
Jan 26, 2011 12:51 PM
grrmrgal75
Aug 25, 2006 04:13 PM
