2000 s10 won’t start unless parking break engaged. why?
Old Nov 8, 2022 | 10:42 PM
blazerconfuzed's Avatar
blazerconfuzed is on a distinguished road
Default 2000 s10 won’t start unless parking break engaged. why?
Hello, i’m new and very inexperienced/lacking car knowledge so any and all help is appreciated! i have a 2000 s10 that won’t start, no crank, lights on dash come on and overhead lights work when clicked on, but when i try to start everything dies and all lights go black. will eventually start when hooked up to jumper cables. but something odd i found out today is that it starts up no problem when the parking break is engaged, why would that be and where should i look to further diagnose the problem?
Old Nov 10, 2022 | 01:04 PM
First thing to check is the health of the battery. This becomes important when temperatures drop. Some things may work and others may not with a battery that is old and not able to deliver the current necessary but still has the voltage needed.
The best way to check this is with a proper tool at an autoparts store. Measuring the voltage alone is not sufficient.
Old Nov 12, 2022 | 09:33 PM
hi sorry for the delayed response. so i got over to an auto parts store and had them check the battery, which is bad so that’s probably my first problem solved, and there was a pretty loose connection that is not tightened. but why would my car start up just fine with a bad battery ONLY if the parking break is engaged? does that mean there’s a bad sensor or fuse or something of that nature?
-Thanks
Old Nov 12, 2022 | 10:30 PM
-Thanks
Making progress!
As for it only starting with the parking brake engaged, it could have been a coincidence or that some other system was energized electrically drawing battery power when the brake was released.
blazerbagpipes
Jan 27, 2013 06:10 AM
chrishorton
Feb 3, 2012 03:18 PM
taleahj
Feb 24, 2010 06:09 AM
wesley!
Jan 30, 2010 02:26 PM
araguz90
Sep 3, 2009 12:53 PM
