-   -   2000 trans into a 2002 (https://blazerforum.com/forum/engine-transmission-35/2000-trans-into-2002-a-44423/)
02blazerz 05-12-2010 01:38 PM
hey i have a 2002 chevy blazer and my tranny went would a 2000 zr2 tranny fit and mount in thanks let me know a.s.a.p
swartlkk 05-12-2010 02:53 PM
*Moved into a new thread* - Please do not post off topic questions in another member's thread. It is very rude.
So long as both are 4wd or 2wd (yes there were 2wd ZR2's), yes, it should bolt up without issue.
kickme005 05-12-2010 07:11 PM
would a enigne and tranny from a 95 blazer 4x4 4dr fit into 98 blazer? if not direct, what needs done to make it fit?
swartlkk 05-12-2010 07:12 PM
Nope and what is different is covered in other threads. Suffice to say, it is not worth the effort seeing as how the heads on up are different and cannot be used. There are differences in the block/timing cover as well that will give you headaches.
