-   -   2001 4x4 problem (https://blazerforum.com/forum/engine-transmission-35/2001-4x4-problem-38719/)
2001 4x4 blazer 01-01-2010 03:04 PM
2001 4x4 problem
has someone ever had a 4x4 blazer that shifts in 4x4 but doesnt work
i lifted the front tires up and it is in gear but they dont pull on the ground
2001 blazer, dealership said it might be front axle sleve
Brian_D 01-03-2010 07:48 PM
i sorta had this same problem..
only the right side turns when 4 hi or lo is engaged...
sadly i don't know what the problem is yet..
swartlkk 01-03-2010 10:07 PM
Sounds like you have a problem with the front axle engagement.
