-   -   2001 blazer 3rd gear just revs? Tranny swap 04 blazer? (https://blazerforum.com/forum/engine-transmission-35/2001-blazer-3rd-gear-just-revs-tranny-swap-04-blazer-80652/)
PogiMoto 07-24-2013 08:37 PM
Hey everyone, my 01 blazer 4dr is having transmission problems. When I drive, it goes to 1st and 2nd fine, but when it goes into 3rd gear it moves normal for 2seconds and than the rpm just shoots up high like there's no gear? Well anyways, I also have a 2004 blazer 4dr same color and everything as my 2001 but its motor just finally hit the fan after 200,000+ miles... I'm looking to just swap the tranny out of my 04 into my 01. Are both tranny's identical? And how hard is it to remove the transmission? I also heard its just a solenoid or valve which is causing it not to go into 3rd gear? Now if I can avoid just swapping trannys can I just swap the electoral internals from my 04 to my 01 and 3rd gear works again? Please help before I end up getting robbed from a transmission shop doing the swap. Thanks
PogiMoto 07-26-2013 07:42 AM
Bump... Anyone?
AndrewO1991 07-26-2013 08:00 AM
they will swap out as long as both are 2wd or 4x4. 4x4 wont swap into a 2wd and visa-versa
PogiMoto 07-26-2013 03:31 PM
Alright sweet! Thanks
cjb2145 06-02-2014 11:31 AM
I'm having the same problem, what did you figure out with yours PogiMoto?
