2001 Blazer Runs Hot When AC Running
"I do know that when it was running hotter than usual the other day, the fan was not running as fast as it used too. It was slow and looked wobbly."
Should not be turning slow. Sounds shot to me. If you don't know how old the clutch is just replace it. They can go bad gradually. You can still test it by having someone turn the engine (at operateing temp) off while you watch the fan. It shouldn't make more than a turn if that. Check that wobbling by trying to rock the fan sideways. Also watch for play at the water pump. Make sure you get one that specifies for a/c.
http://www.napaonline.com/Catalog/Ca...312_0382753852
sexy blazer
12-31-2014 09:39 AM
zakm0n
01-10-2011 11:42 AM
ravenhurst
15
04-26-2009 07:53 AM
