-   -   2002 Blazer LS 2Dr 4x4 1st to 2nd shift problems (https://blazerforum.com/forum/engine-transmission-35/2002-blazer-ls-2dr-4x4-1st-2nd-shift-problems-64207/)
brendan127 Oct 20, 2011 02:12 PM
My blazer is shifting hard when going from 1st to 2nd. I've read that this may be the valve body, but it said it was for the 2000 blazer at the latest. So any ideas? Another problem I'm having is that my air intake hose keeps falling off and yes I am tightening the hose clamp.
http://i247.photobucket.com/albums/g...lazer_temp.png
This is the hose I am talking about.
grizzstang Oct 20, 2011 02:55 PM
How many miles on your Blazer? Is your check engine light coming on?
bromanjr Oct 20, 2011 03:13 PM
I see something shiny where the arrow is pointing ?. On my 2000, there is nothing shiny there, just an IAT sensor stuck in the backside of the tube. Is your hose actually split/joined at that spot?
Your PCM may be confused by the hose falling off and cause a rough shift.
Bad motor mount might allow too much movement in the hose.
brendan127 Oct 20, 2011 03:49 PM
148,xxx Miles. And my check engine light isn't coming on.
The "shiny thing" you are seeing is where light was coming through some trees. There was a lot of junk in the air box and it seemed to fix the shifting and the hose for now anyways but idk. Thinking about getting the BOMZ Racing air intake kit.
Amazon.com: RED1996-2005 96 97 98 99 00 01 02 03 04 05 Chevy S10 Blazer Xtreme Sonoma Jimmy Hombre Bravada 4.3L V6 Cold Air Intake: Everything Else
brendan127 Oct 20, 2011 07:00 PM
Idk if this could help but here is a video of the engine movement in high rpm's.
2002 Chevrolet Blazer ZR-2 Rev from Engine Bay - YouTube
brendan127 Oct 21, 2011 09:10 PM
bump.
Dean Caulfield Mar 27, 2013 05:37 PM
My '02 Blazer 4WD is having the same issue. My service engine light has been on for about three months (haven't had the money to get it checked). The issue didn't start until I over-filled the gas tank. It currently has 52k miles on it.
Any help would be much appreciated.
