Yes mrspeedy69 the actuator door is working as is the 4X4. Diaita the radiator and reservoir are at proper levels. I went ahead and changed out the Thermostat with one at 195 degrees, this I think has solved the problem. The old one I beleave was stuck closed. I will more than likely go ahead and flush the heater core if I get some decent weather, couldn't hurt. Thanks to you all
Thermostat is usually the culprit. if shes blowing hot now you scored.
