2nd Gen blazer Xtreem-Overheating, No heat, No Vacuum
My blazer overheats within 10 miles of driving and That's from a cold motor, I have no heat, and when I start the motor there is zero change in my coolant level when the radiator cap is off as if there is no vacuum draw on the system. I can't find any leaks other than when it boils out when it's overheated. Do you guys think it's a bad water pump or heater core. I have already put a new thermostat in. And about 6 weeks ago my water outlet tube from my thermostat cracked and I put a new tube on then. Also I've tried jacking ps up and burping system any other advice would be great
Originally Posted by Yohan
(Post 682855)
| All times are GMT -5. The time now is 03:53 PM. |
