2wd to 4wd to 2wd issue
I've been searching the site for a similar problem but I haven't had any luck. Sometimes when I start up the rig the 4wd switch on the dash (4 button) is in 2wd. On its own it will shift into 4 lo. When I push the 2wd button it blinks but sometimes stays in 4 lo. If I push the auto button the auto light comes on steady. Other times it goes back to 4 lo. Sometimes when I start up the rig it's in 4 lo when it was in 2wd after parking and shutting off the engine. I've checked all the vacuum hoses which I replaced this last summer using Christines thread and I don't find any issues. Possibly an erratic 4 button switch?
Might be worth it to check the switch out. Or maybe unplug it completely and see how it acts
If you are lucky, maybe find one in a junkyard for cheap, and see if the behavior persists. If your junkyards are like mine, though, they've all been long since picked up lol |
If I unplug it will it stay in 2wd?
It should. That's how my 95 works. Not sure about the later ones with auto 4wd
Originally Posted by cleburne red
(Post 701929)
Originally Posted by G0LFADD1CT
(Post 701924)
It hasn't shown up again, but now when selecting 4 hi and putting it in D or R I can hear the shift take place. When I press on the gas pedal nothing happens at first and then it bangs and starts moving. Wish I had a garage....
How long has it been since you checked/changed your differential fluid? Just a thought...
Originally Posted by go chevy
(Post 702938)
