-   -   4.3 Engines compatible with a 99 Blazer (https://blazerforum.com/forum/engine-transmission-35/4-3-engines-compatible-99-blazer-27863/)
instygator 02-22-2009 08:07 AM
I have a 99 Blazer that needs a new motor, what years are interchangeable?
swartlkk 02-22-2009 06:59 PM
RE: 4.3 Engines compatible with a 99 Blazer
As far as the motor itself goes, anything from 96 thru mid-02. If you find an engine from a 2002 model year, you need to make sure that it has an EGR valve. If it does not, you cannot use it.
