-   -   4.3 oil filter adapter seals (https://blazerforum.com/forum/engine-transmission-35/4-3-oil-filter-adapter-seals-27727/)
shamipacqu Feb 18, 2009 10:13 AM
What is the best way to replace oil adapter seal? Please help if you can. The motor is in the vehical.
swartlkk Feb 18, 2009 05:37 PM
RE: 4.3 oil filter adapter seals
*Moving to Engine & Transmission*
I assume you have a 4wd or else you probably would not be asking, but your vehicle specs would be very helpful. Removing the front driveshaft gives you more access to the adapter. Not a lot of access, but more.
