4.3 vortec replacement
Hi and hello forum..... I own a GMC 4x4 jimmy 1999 (4.3 vortec)..... any good (quality and fair price) for motor replacements? thanks for any help.
Originally Posted by calrow99
(Post 622976)
I see they also have a rebate going on...which of course wasn't there when I ordered mine. *sigh* Get back to me in about a year or two and I'll definitely be able to tell you how the engine worked out. ;) Right now,...so far so good (knock on wood...knock, knock,knock). Also, as you can tell from the images, these are long blocks. There are other items you'll have to buy..like buying the Felpro intake gasket set instead of the Victor-Reinz they send you. You want to buy a new timing cover (can only get it from the dealer). Cap, rotor, plugs, oil, coolant, etc. So even if your trucks direct swap is the DCW1 ($1758.00) you can probably count on being much closer to (if not over) $2300.00 by the time it's all said and done. Engine | AutoZone.com |
