-   -   4.3 x to w motor swap (https://blazerforum.com/forum/engine-transmission-35/4-3-x-w-motor-swap-95576/)
seth677 10-23-2017 04:04 PM
I blew the engine in my 2003 blazer it’s is a vin x what would I need to do to swap it with a vin w engine?
LesMyer 10-26-2017 08:58 AM
Change intake manifolds (2003 has no EGR). If vin W is 1996-2000, you will also need to deal with mounting of different knock sensor that is on your 2003. Otherwise the 2001-2002 vin W has the the same knock sensor.
