-   -   4.3L ignition upgrade kits? (https://blazerforum.com/forum/engine-transmission-35/4-3l-ignition-upgrade-kits-78729/)
gitch93 04-19-2013 08:21 PM
just wondering if any ppl have done the ignition upgrade kits on the 4.3. i have cap,rotor,new distributer,plugs,wires and coil. i was wondering if msd ignition digital box or mallory will work on our systems?
Twip 04-19-2013 10:18 PM
i had a buddy do it on a 1st gen, but i dont know how well it worked out AND weather or not he had it hooked up right.....
just sayin
gitch93 04-19-2013 10:42 PM
would be a great mod for the truck to liven it up some more give me the extra power for hauling and offroading
Captain Hook 04-19-2013 10:49 PM
Your 2000 has EDI: The CKP generates a 3X pulse, (accurate to 20K+ RPM) and sends it to the PCM. The PCM calculates ignition timing and sends a pulse to the ignition module, (also accurate to 20K+RPM). The module sends a pulse to the ignition coil to fire it. The OEM coil is capable of 40K+ volts, (secondary ignition only uses ~4K). No need to upgrade, it's already overkill ;) AC Delco plugs, cap & rotor and make sure camshaft retard is within specs. Doesn't get any better!
gitch93 04-20-2013 12:50 AM
good to know thx captain pretty in depth stuff but i learned more today. i run a full ignition system just was wondering if a msd box would help it but ill keep it oem.
TStoddard 02-22-2019 09:07 PM
Thanks Captain, good info to know. I burn through caps & rotors every year regardless of what I pay. Really plays with performance & mileage. I'll have to hunt down some AC Delco on Amazon and give that a shot.
Captain Hook 02-23-2019 04:43 PM
Originally Posted by TStoddard (Post 703646)
...I burn through caps & rotors every year regardless of what I pay.
Might want to consider having CMP, (camshaft retard) checked, and adjusted if necessary. Spec is zero degrees, (+ or - 2 degrees). If it's out of spec, it will cause premature cap & rotor failure, not to mention affecting performance and fuel mileage.
