4 x 4 wheels not engaging
I have a 1984 S 10 Blazer 2.8 4 x 4. Put in a shift lock cable to get rid of acuator thinking that was my problem. When I shift into 4 wheel drive the transfer case locks in but the front wheels won't engage. Any suggestions? Thanks
RE: 4 x 4 wheels not engaging
do you hear any grinding or any other weird noices after the 4x4 is engaged?
None??
The front drive shaft will spin when engaged. I pulled the cable out and took a pair of pliers and pulled on the shaft to try and make it engage and no luck. What should I do next? Thanks
double check all ur vaccum lines first and then if thats still all good and it wont engauge then its something in the front diff. prolly the shift fork
Any info online for tearing it apart? Thanks
| All times are GMT -5. The time now is 10:57 AM. |
