Community
Search
Sponsored by:
Sponsored by:
4Hi but not 4Lo
Old 12-04-2012, 10:13 AM
kendog is on a distinguished road
Default 4Hi but not 4Lo
Greetings all. Not a transmission man, so I need some more wisdom. My '04 with the 3 button on the dash will not go into 4Lo. I can get 4Hi, but when I try the low gear the light on the button blinks for a minute and it goes back to high gear. Any ideas?
Old 12-04-2012, 01:04 PM
aa21830 is on a distinguished road
Check out the "4x4 no worky" thread in the DIY section. Odds are it is the encoder (shift) motor, but there is a TCCM diagnostic procedure in there which should narrow it down for you.
Old 12-05-2012, 12:10 PM
seen that before. doesn't have anything for my particular situation though. I'm gonna see if I have any codes stored and go from there.
Old 12-05-2012, 02:30 PM
That's what I meant...tracking down the codes (post #5 in that thread). Have never had to do the DTC procedure, but seems like it ought to be fairly easy.
Old 12-06-2012, 06:07 AM
mmmrodge is on a distinguished road
did you put it in Neutral when hitting 4LO button?
Old 12-07-2012, 05:30 PM
always in neutral when I hit the button. anyone got a pic of where I hook up to get the codes?
Old 12-07-2012, 05:49 PM
rockp2's Avatar
rockp2 is on a distinguished road
It would help to know what vehicle you're talking about. Don't have a pic handy, but it should be under the drivers side dash. Either near the top of the parking brake or under the steering column. You probably will have to get your head near seat level to see it.
The year of your vehicle also matters, as it could be OBDI or OBDII.
Found a pic. Not necessarily for a Blazer, but the location is in the general area.
Edit: Oops missed where you did list your year.
Last edited by rockp2; 12-07-2012 at 09:46 PM. Reason: Found photo; fixed my dumb-a** mistake
Old 12-07-2012, 07:10 PM
cleburne red's Avatar
You just jumper one of the pins on the OBD plug to ground. I forget which pin, it's on this site somewhere. The 4wd buttons will flash a sequence, and display the stored codes. You said yours is an '04, so it is definitely OBD II, and this will work.
Old 12-10-2012, 03:00 PM
No codes are stored. This is gonna get ugly...
Old 12-10-2012, 07:57 PM
coolasice will become famous soon enough
mine has trouble getting out of 4lo most of the time, i think my encoder is just old and dieing... hardly use 4lo tho
Quick Reply: 4Hi but not 4Lo
