| bowtie-72 |
12-29-2013 11:18 PM |
Is A 4L60e 4WD The Same As A 2WD?
I have a quick question for you transmission guys. I know this sounds stupid, but is a 4L60e 2WD transmission the same as a 4WD? I know that all of the application guides make the distinction between the two, but it looks to me like if you take the tailshaft off of a 2WD trans. you are left with the same 5 bolt mounting pattern as the transfer case. I would like to know because I will have to replace the tranny soon in my `94 4WD S-10 Blazer and may run across a good 2WD unit. If it is otherwise the same, I could just pull the tailshaft housing off and put my transfer case on. Thanks, Jeff.
