-   -   4L60E - hp and torque rating? (https://blazerforum.com/forum/engine-transmission-35/4l60e-hp-torque-rating-95640/)
error_401 11-01-2017 11:43 AM
Does anybody have the max. hp and torque ratings for the 4L60E through the years?
Trying to figure that one for my build.
LesMyer 11-01-2017 02:49 PM
4L60-E
The 4L60-E is rated to handle up to 360 ft·lbf (488 N·m) of torque. It weighs 133 pounds without transmission fluid.
4L65-E
An updated 4L60-E, the 4L65-E (RPO M32), was phased in the 2001 model year when coupled behind the 6.0 Vortec. Five-pinion front and rear planetaries, along with an additional 3/4 clutch allowing 7 clutches in the input housing and induction hardened input shaft assembly, were improved to withstand up to 380 ft·lbs (515 N·m) of torque.
error_401 11-03-2017 06:34 AM
Thanks,
Nice - it will be enough then for my mild build. I'll for sure not be over 300 ft-lbf (400 Nm) on the torque rating. So I will have it rebuilt as I have no time to dig into that as well.
