Shouldn't have to add anything other than DexronVI fluid. The 180F temp, was that engine coolant or directly from the TFT sensor?
I agree, a normal operating transmission should not need anything else. This one is messed up.
The 180 is the transmission temp indicated by Torque which I assume is coming from a sensor somewhere in the transmission. |
If that's the TFT sensor reading, at 55F ambient, there's a serious problem going on in the trans.
I agree. That is the whole reason of the thread, looking information about the transmission because I either going to get one from a pull-a-part or going to rebuild it myself. I doubt i will get an used one anyway, im inclined on rebuilding it myself.
Front pump provides hydraulic pressure to operate the transmission. It is the first thing behind the torque converter. Yes it is fixable but you first need to remove the transmission.
