4l60e torque conv, removal( frustrated)
ok i have removed several 4l60-s but this blazer has a one piece bellhousing or non removable inspection cover! all the others had a lower removable plate to access the converter bolts how the hell do you access them on this without seperating the trans/engine? or is that the trick?
You have to remove the starter to access the torque converter bolts.
| All times are GMT -5. The time now is 09:29 AM. |
