-   -   4l60e week of hell (https://blazerforum.com/forum/engine-transmission-35/4l60e-week-hell-77908/)
dehackin Mar 19, 2013 05:07 PM
hey i hate to say it but when your right you are right can i get away with just mapp gas alone because that is about the only thing i have access to that would be in my buget like one of the portable torches from lowes i think just the bottles are about $10 not the little cig lighter torch
1sttimejimmyowner Mar 19, 2013 08:14 PM
Just get a regular propane torch head and use that on your map gas.It will take about 10 minutes or so to get them red hot.
dehackin Mar 19, 2013 10:00 PM
Ok thanks for your input will start on that tomorrow and thanks for all your help and advice thrhoghout this
1sttimejimmyowner Mar 20, 2013 11:40 AM
Not a problem thats why were here just doing my part.
dehackin Mar 21, 2013 07:07 PM
I know we are all human even me I could kick myself it turned out my manifolds were threaded so I took them off and sent them 2 a buddy that is drilling them out for mei got the tranny stabbed in today then wenta cut grass at my other biddys house came back and put the shift cable &bracket on hope I can hear it run before this weekend is over keep
1sttimejimmyowner Mar 21, 2013 09:20 PM
So Im kinda lost are you sayin that the bolts in the manifold are broke and not the ones that connect the ypipe to the cat?Cause yeah the manifold bolts are threaded but Ypipe bolts are pressed in at least on my 96 they were.I replaced them with threaded.
dehackin Mar 21, 2013 11:18 PM
From manifold to y pipe where doughnut gaskets go are threaded y pipe 2 cat are pressed
alllw2000 Apr 3, 2013 04:03 PM
Any updates on your transmission rebuild? I am about to embark on this journey. We have no reverse backing out of the garage so there it sat for over a year now. This was suppose to be an uncle-nephew project but has turned out to be a true “do it yourself” rebuild. Read many web posts and viewed many YouTube videos on this 4l60e. Looks like I have a sun shell problem. I can rig a spring compressor with what tools I have. My only worry is those Teflon seals and how to install/resize them without that special tool. How did you handle them seals?
