-   -   4wd to 2wd Conversion Question (https://blazerforum.com/forum/engine-transmission-35/4wd-2wd-conversion-question-65325/)
BLAZER97LS Nov 23, 2011 09:58 PM
Would it be possible to make my Blazer 2wd by just swapping for a 2wd transmission, dropping the transfer case, and getting a 2wd drive shaft?
xgiovannix12 Nov 23, 2011 10:01 PM
it has been done before with out replacing the transmission
I bet the person who did so will stop by this thread soon
chris015 Nov 23, 2011 10:17 PM
oh dawgggggg here we go! lol.
I removed ALL of my 4wd stuff,but the transfercase and tranny...why? because you'd have to either refabricate the torsion bar crossmember or else your driveshaft wont work with it(crossmember is in the way)...I found a write on where someone took a driveshaft carrier bearing,installed it on the crossmember and made a 2pc driveshaft etc. I cant find it.
gio,there. my work is done. lol..
if you have anymore questions message me OP
Just pull the front driveshaft,front diff,cv axles,put the outter cv axle ends back in the front hubs,or else your hub bearings will crash and burn as soon as you pull out of the driveway.
xgiovannix12 Nov 23, 2011 10:20 PM
your the only one that explain this .Your the one who deleted half of truck
did you ever delete the fender wells ? I can still picture the fenders falling off (Giggles)
chris015 Nov 23, 2011 10:23 PM
I didnt...i love my cruise control,and i remembered its bolted to the inner fender...im not sure how well it would work flopping around. thats allotta muddy bolts to pull to find out it wouldnt work..
Trucks gained a lil weight with the sub box and the spare tire i got for it..
xgiovannix12 Nov 23, 2011 10:24 PM
finally a spare i bet you still dont have a jack tho
chris015 Nov 23, 2011 10:25 PM
actually....no....LOL....i hate the little scissor jacks,and imma have to stop being a cheap ass and buy a bottle jack.
xgiovannix12 Nov 23, 2011 10:27 PM
i agree i need a bottle jack also
any ways Lets not thread jack
sorry BLAZER97LS
pettyfog Nov 24, 2011 06:22 AM
Just pull the
A - front driveshaft,
B1 - cv axles,
B2 - {Dissassemble cv at outer}
B3 - put the outter cv axle ends {spline shaft} back in the front hubs, {Torque to specs}
front diff, {optional}
Took liberty of edit, Those 4 steps ought to solve any drivability probs.. unless your transfer case is stuck in Lo, somehow
Note: Relabeled steps for 'A' and 'B' levels. A is easiest to resolve some 4WD 'binding' issues. If they are Transfer case related 'A' will usually free it up. But the front diff will still be a small drag. If desired then do 'B'. You must do ALL of 'B'.
Here's how to disassemble the joint from shaft
http://www.ehow.com/way_5638387_diy-...-cv-joint.html
If that isnt clear enough, I recall Chris saying in another thread 'just beat the crap out of it till it comes apart'... LOL
After all.. they are cheap on ebay.
Here's one $85 pair rebuilt
xgiovannix12 Nov 24, 2011 10:41 AM
DIY Rebuild a CV Joint | eHow.com
you just need a big effin hammer :icon_wink:
