4wd problem
Old 11-23-2017, 05:02 AM
Nixoncc's Avatar
Nixoncc is on a distinguished road
2005 Dakota manual for NV233 electrically actuated reads:
4HI to 4LO or 4LO to 4HI
NOTE: When shifting into or out of 4LO some gear
noise may be heard. This noise is normal and is not
detrimental to the vehicle or occupants.
Shifting can be performed with the vehicle rolling 2-3
mph (3-5 km/h) or completely stopped.
The 1991 - 1994 with the electric NV233 with dash electrical switch are the same.
BTW:
Switching the HI-LO range should be accomplished only with the transmission in NEUTRAL.
TCCM will sense it and flash or do nothing.
The thing is that I can hear the 4lo tries to engage but then returns to the 4hi in a few seconds.
This is in neutral
Old 11-24-2017, 04:30 AM
error_401 is on a distinguished road
BTW
Can you give us the vehicle information?
Year, Make, Model, still not sure about which Blazer we are talking.
Old 11-24-2017, 06:42 AM
Nixoncc's Avatar
BTW
Sure!
It's a 99 Blazer LT
Old 11-24-2017, 08:31 AM
LesMyer's Avatar
LesMyer will become famous soon enough
Originally Posted by Nixoncc
Sure!
It's a 99 Blazer LT
As I described is the preferred method for either NP233 or NP236. Also included here is a tip if it is a NP233 (3-button) and won't go into 4lo.
https://cdn.dealereprocess.net/cdn/s...001-blazer.pdf
I'm done
dwmlr
12-10-2015 07:39 PM
2001 ZR2
01-16-2010 12:39 PM
LJ809
11-25-2009 08:43 AM
waterskier98
03-04-2009 03:15 PM
Mikes1Addiction
01-12-2007 02:08 PM
Quick Reply: 4wd problem
