4x4 dash lights, sound, does not engage
Old Oct 9, 2012 | 02:05 PM
aa21830's Avatar
aa21830 is on a distinguished road
Agreed above....what the mechanic may not know is there is a diagnostic procedure where the TCCM will tell you a few things about what's going on with the 4x4 electronics. This may prevent throwing money at the problem, which is sounds like what he is suggesting. See the DIY section, "4x4 no worky" thread.
Old Oct 10, 2012 | 06:20 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
Ya, dont think its the switch. Im thinking encoder motor or possible TCCM. It all depends on the test i described.
Old Oct 10, 2012 | 11:03 AM
sailors2's Avatar
sailors2 is on a distinguished road
initial report is that the cable from the actuator is seized.
Old Oct 12, 2012 | 10:14 AM
sailors2's Avatar
well some good news i think, but not elated yet. they installed the cable from the actuator and it does engage the front wheels....BUT...the dash lights continue to blink; lights do not go solid...please help as it is up on the rack and they are working on it as we chat.
Old Oct 12, 2012 | 11:18 AM
sailors2's Avatar
Default 4x4 DASH LIGHTS LOOK
new to forums and don't know how to link together BUT i have thread 4x4 dash lights. to continue, the mechanic installed new actuator cable and the front wheels now engage, turn, sounds good...BUT...dash lights continue to blink and will not go solid. he's working on it as we chat. suggestions?
Old Oct 12, 2012 | 07:04 PM
50lb_cat's Avatar
i had a simialar issue, where I new the front was engaged but no lights or the lights would go off every now and then. Just replaced the switch and all was well.
Old Oct 12, 2012 | 07:50 PM
richphotos's Avatar
What about a tccm relearn, I know I say that a lot, but the tccm could still be thinking there is a problem with it engaging, even though it is working, so a relearn could correct the problem.
Old Oct 12, 2012 | 08:06 PM
xgiovannix12's Avatar
Sounds like a bad connection somewhere
check the Pins on the encoder motor plug.
Old Oct 12, 2012 | 08:36 PM
sailors2's Avatar
i have news....it might be good...and some bad...tomorrow!
Old Oct 13, 2012 | 09:59 AM
Try a TCCM relearn, pull fuse, wait 10 min to make sure it's gonna work, plug it in. see if that works. If not checking wires may be a good idea and could be your problem. Sounds like something isnt telling it to stop shifting. Encoder motor could be bad, wiring could be faulty, or TCCM could be at fault. This system has similar symptoms for multiple problems.
