-   -   4x4 questions (https://blazerforum.com/forum/engine-transmission-35/4x4-questions-15366/)
marc.doucette 12-14-2007 07:50 PM
4x4 questions
I just got back from brother inlaws garage.....heres the problem my 4 wheel drive has stopped working...everything worked fine no vacuum leaks and actuator is in tack....when i hit 4x4 button on dash i hear it click on right side in or by glove box which it used to do before and now the lights only flash and now i can't remember if front shaft should be turning at all times or not....also is there a relay of some sort somewheres that i should be checking and where is it
marc.doucette 12-14-2007 07:51 PM
RE: 4x4 questions
swartlkk 12-14-2007 08:25 PM
RE: 4x4 questions
*Thread Closed - Duplicate Post*
Please keep things in the first thread you created on this subject --> 4x4 front shaft
