-   -   4x4 won't go to 4hi (https://blazerforum.com/forum/engine-transmission-35/4x4-wont-go-4hi-13374/)
EvilPotato 10-01-2007 07:20 PM
4x4 won't go to 4hi
when i press 4hi, 4hi button lights up as if there were no problems, but it engages in 4lo instead.i can go back to 2hi from there but i have no 4hi. so i'm assuming the vacuum to engage 4x4 works and whatever switches it from 4lo to 4hi is the culprit.
swartlkk 10-01-2007 07:32 PM
RE: 4x4 won't go to 4hi
Do you have Auto4wd? If not, check out the thread in the DIY section. OBD2 Non-Automatic Transfer Case Diagnostics
