5-speed
well... i have a '91 s10 blazer 4.3l auto-OD 4x4. and im trying to find a 5 speed tranny that will work in this truck. i already did a search and all i found out was that a 2.8l 5speed will not fit due to the differences in bolt pattern.. thanks..j.b.
RE: 5-speed
you need a 5 speed for a sbc or 4.3, one from a 4x4 s10, blazer, or full sizewill work.
RE: 5-speed
The only way it'll fit from a full size is if it's the NV3500, the NV4500 is too big.
RE: 5-speed
You can make the NV4500 fit, just a matter of how much work you want to do ti make it fit.
Swapping from a auto to a maual is a lot of work to begin with. Hell, just pulling the tranny is a lot of work. :D |
RE: 5-speed
At least, since it's an OBD1 vehicle, he might be able to get away with fooling the computer to thinking the transmission is always in 3rd gear by jumpering one wire or grounding it...
That's the easy way out on the 1st generation W-Body cars, lol. |
RE: 5-speed
thanks a lot guys.. thats wat i needed.. the only other time i did this was an 70 c15 chevy and it was just stock 3 spd auto to stock 4 speed manual from another 70gmc.. this project seems to be looking like alot of work, but im lookin forward to it.. thanks again.
| All times are GMT -5. The time now is 09:16 AM. |
