5-speed won't shift
Old Feb 14, 2007 | 04:17 AM
FieroGuy9890's Avatar
FieroGuy9890 is an unknown quantity at this point
Default 5-speed won't shift
I'm looking at buying a 96' Blazer with the 4.3L and from what the current owner told me one day when him and some friends were running it pretty hard it stopped shifting. I'm pretty sure he said that the shifter won't even move at all. I just want to know if it's something worth while to buy or if the fix is going to be too difficult or costly to be worth my while. So does anyone know what the problem or fix could be? Thanks in advance.
Old Feb 14, 2007 | 10:46 PM
Default RE: 5-speed won't shift
BUMP. Any idea? Someone on another forum mentioned that they thought it could be a broken shift fork?
Old Feb 15, 2007 | 03:18 AM
Chevy Lover's Avatar
Does the truck move? Is it stuck in gear and can you tell what gear?
Old Feb 15, 2007 | 03:28 AM
Umm not sure since I haven't seen it yet. I'm pretty sure that it's in gear. anddoesmove. But I have no clue which gear at the moment. I will be able to take a good look at it in like a week or so. But before i do that I was just hoping to get a few good ideas of what the problem was and how much parts will cost, I can install them myself I just need to find the problem.
Old Feb 15, 2007 | 10:13 AM
drperry's Avatar
Try and see if the truck will come in and out of gear when it's shut off...
Old Feb 15, 2007 | 02:17 PM
4lowlife's Avatar
I wouldn't buy it. It could need synchros or more parts. If you want it, offer him half what he wants. Your looking at alot of money to spend on the unknown.
Old Feb 15, 2007 | 02:51 PM
Seeing as how you can pull a tranny from a yard for pretty cheap, I'd go for it. Just go at it expecting to replace the transmission. Other than being heavy, manual transmissions are a sinch to swap. Plan on replacing the clutch while you have the trans down.
Old Feb 15, 2007 | 05:49 PM
I don't think that the shifter will move at all even with the engine off. I had someone else who had a Chevy truck tell me they had what seemed to be a similar problem when they were running theirs hard, and that was that the ball/selector assembly popped out of where it was supposed to be and got stuck. And that for him all he had to do was line everything back up again and reinstall the shifter but said that things could be bent or broken.
Old Feb 15, 2007 | 06:25 PM
drperry's Avatar
It's possible that it could just be bent or broken, but if they're selling it at a dirt cheap price, and everything BUT the transmission is good, then it'll be an easy fix... even if you've gotta replace the whole shebang... Hopefully they didn't run it that hard all the time...
Old Feb 16, 2007 | 12:11 AM
4lowlife's Avatar
Find out if any tranny work was performed prior to this. If the shifter was removed from the tranny and it was not in neutral you can run into a problem like this.
