6.0 Liter Encine Swap into a 90 k5 blazer
anybody done this swap?? thinking about doing it any advice or info appreciated
i'd do a 7.3L, some of the old k5s had a 6.2L diesel.
It shouldn't be too difficult. Basically, tear out the ECU that you have and replace it either with a stand alone unit or try to integrate in a stock PCM and engine harness. All depends on what you can get with the motor.
You will have to upgrade the fuel system as well because the fuel pressure required for a TBI motor is a lot lower than what is required for a MPFI engine. Those LS based engines can make some wicked power though! |
do a build thread if you end up doing it.
6.0 is defiantly a nasty engine but going to obii is going to be a plan.
Originally Posted by TheBrettster
(Post 297922)
pain? |
Could be a pain or could just be $$$. There are quite a few stand alone ECUs available for the LS engines that are quite easy to implement.
That would be sweet. Nice power!
Originally Posted by Spectreblazer
(Post 297879)
why the hell would you put in a Ford diesel?!? if anything, you upgrade to a 5.9 (or a 6.7 if you have really deep pockets). those Cummins are pretty much a bottomless pit of power. :D |
(Post 298134)
| All times are GMT -5. The time now is 05:23 PM. |
