700r4 transmission problem!!
Old Dec 26, 2012 | 09:27 AM
chevymann's Avatar
chevymann is on a distinguished road
Default 700r4 transmission problem!!
ive got a 91 s10 blazer with a 350 small block with an elderbrok tunnel ram with to holly 450s set up as a street/ drag truck but recently my trans has been screwin up ive checked tpb ( throttle position bracket) cuz i dont have the v6 anymore so no tps ( throttle position sensor) so im at a lost of whats goin on with it. i can take off from first but my rpms get up in 3 grand and wont shift untill i let off gas same with all gears and no od but p and n and r are fine just the normal gears and with slowin down it doesnt down shift at all i have to rachet into n to get it back into first. any ideas?!?
Old Dec 26, 2012 | 02:11 PM
Twip's Avatar
possible that the valve body is going out....might need a rebuild on that.
Old Dec 26, 2012 | 08:28 PM
chris015's Avatar
trans is shot. time for rebuild.
Old Dec 26, 2012 | 09:14 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Take it to a trusted certified trans mechanic and let them do a road test.Post your answer and we can decide what the next step is.
Old Dec 27, 2012 | 01:11 AM
neo71665's Avatar
Do you have the correct bracket for the TV cable and have it adjusted correctly?
Old Dec 27, 2012 | 10:57 AM
LeWhite's Avatar
Governers' stuck or sprigs broken inside
MTV up valve sticking
TV boost valve in pump
Oil filter needs replacing
Old Dec 30, 2012 | 07:22 AM
sleepy96's Avatar
sleepy96 is on a distinguished road
Just did same rebuild...well assisted with it anyway. We had same problem. For the OD problem we simply had to adjust the kickdown cable, ours was just a bit too long. I didn't work with the downshift issue but if I remember correctly he had to adjust the TV cable to fix that problem.
bbthekid
Nov 23, 2014 01:12 AM
Diverknox
Dec 6, 2009 11:48 PM
Always Something
Mar 11, 2009 06:48 AM
radje00
Sep 17, 2008 12:32 AM
radje00
Sep 9, 2008 10:49 PM
