78 Blazer High RPM Problem
hi
1978 Chevrolet Blazer , Manual , carburetor V8 350 Ci when i starts the engine the RPM jump over 3000 and stay there , no matter i put shifter in gear or it's on idle the RPM stay above 3000 ! i have checked the Vacuum and carburetor and also Wire gauze ! now i don't know what to do !!! any Idea ? |
there is a adjustment screw on the carb for the idle. it may just need to be loosened. also make sure its returning all the way back to idle position. sometimes a vacuum line or other crap will get lodged behind it
That is a high idle. Check for a Vacuum leak somewhere. Intake gasket area, carb gasket are where I would start. The carb baseplate could be worn too causing the throttle blades not to fully close.
| All times are GMT -5. The time now is 09:07 AM. |
