| dbarrowjr |
01-11-2014 03:11 AM |
93 4.3 vin z hard start, missing, dieseling...HELP
ok. i need some pro help. i have a 93 4.3 vin z. its just recently, like literally overnight, started screwing up. it turns over for a few seconds then finally starts, it misses at idle and all throughout the driving range from acceleration to slowing down, and it diesels or "runs-on" for about 3 seconds and finally dies down with a finishing knock after shutting off the key. i put a new fuel pump, fuel filter, fuel pressure regulator, plugs, wires, dist cap and rotor button and checked the timing and the gears are lined up to the T. i even put a new timing chain on it bc it had a tiny bit of slop in it but i still have the same problem as before. so...any advice?
